StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention
Quicklinx: 5CB7WS00 Mfr#: ICUSB2321X
Type: Serial adapter
Compatibility: PC
Interface: USB
22 In Stock
£31.73 ex VAT
£38.07 inc VAT
The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
  • Versatile connectivity
    This adapter connects RS-232 devices to USB ports, enabling integration with modern computers and laptops without native serial ports.
  • Efficient data transfer
    With a data transfer rate of 920 Kbps, it facilitates quick and effective communication between connected devices, enhancing overall performance.
  • Robust compliance standards
    Meets FCC and RoHS standards, ensuring safe usage and minimal environmental impact, which is ideal for a variety of applications.
  • User-friendly design
    The Plug-and-Play feature simplifies installation, making it accessible for users of all technical levels without extensive setup.
StarTech.com USB to Serial RS232 Adapter Cable w/ COM Retention - USB Serial Adapter - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
3.5 cm 1.3 cm
Length
42 cm
33 g
RS-232
Data Transfer Rate
920 Kbps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
920 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
FCC, RoHS
Software Included
Drivers & Utilities
3.5 cm
1.3 cm
Length
42 cm
33 g
5CB7 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
5CB7 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
5CB7 StarTech.com 4 Port Black USB 2.0 Hub In Stock £18.08
5CB7 StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention In Stock £62.27
5CB7 StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £13.22
5CB7 StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention In Stock £80.49
5CB7 StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter In Stock £7.93
5CB7 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
5CB7 StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £45.96
5CB7 StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter In Stock £46.21
5CB7 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £94.31
5CB7 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.44
5CB7 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £88.60
5CB7 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £151.52
5CB7 StarTech.com USB to RS232 Serial Adapter In Stock £16.28
5CB7 StarTech.com 4 Port USB to Serial Hub In Stock £78.51
5CB7 StarTech.com UCB C to Serial Adapter In Stock £16.71
5CB7 StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
5CB7 StarTech.com 8-Port USB to Serial Adapter In Stock £340.65
Compatibility: PC
Interface: USB
