The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
Versatile connectivity
This adapter connects RS-232 devices to USB ports, enabling integration with modern computers and laptops without native serial ports. -
Efficient data transfer
With a data transfer rate of 920 Kbps, it facilitates quick and effective communication between connected devices, enhancing overall performance. -
Robust compliance standards
Meets FCC and RoHS standards, ensuring safe usage and minimal environmental impact, which is ideal for a variety of applications. -
User-friendly design
The Plug-and-Play feature simplifies installation, making it accessible for users of all technical levels without extensive setup.
 - StarTech.com USB to Serial RS232 Adapter Cable w/ COM Retention - USB Serial Adapter - serial adapter - USB - RS-232
 - Serial adapter
- Form Factor
 - External
- Interface (Bus) Type
 - USB
- Ports
 - RS-232
 - 3.5 cm 1.3 cm
- Length
 - 42 cm
 - 33 g
- Data Link Protocol
 - RS-232
- Data Transfer Rate
 - 920 Kbps
 - Black
- System Requirements
 - Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
 - 2-year warranty
 - Serial adapter
- Form Factor
 - External
 - USB
- Ports
 - RS-232
- Connectivity Technology
 - Wired
 - RS-232
 - 920 Kbps
 - 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
 - 1 x USB - 4 pin USB Type A
 - FCC, RoHS
 - Black
- Software Included
 - Drivers & Utilities
- OS Required
 - 3.5 cm
 - 1.3 cm
- Length
 - 42 cm
 - 33 g
 - Limited warranty - 2 years
                        StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.54 |
                        StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £31.44 |
                        StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £18.39 |
                        StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention | In Stock | £60.74 |
                        StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £13.36 |
                        StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention | In Stock | £78.53 |
                        StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter | In Stock | £7.93 |
                        StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.62 |
                        StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £44.84 |
                        StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter | In Stock | £45.09 |
                        StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £19.93 |
                        StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £92.00 |
                        StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £25.80 |
                        StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £86.44 |
                        StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £144.33 |
                        StarTech.com USB to RS232 Serial Adapter | In Stock | £15.70 |
                        StarTech.com 4 Port USB to Serial Hub | In Stock | £76.59 |
                        StarTech.com UCB C to Serial Adapter | In Stock | £16.60 |
                        StarTech.com 4-Port USB to Serial Adapter | In Stock | £207.06 |
                        StarTech.com 8-Port USB to Serial Adapter | In Stock | £332.34 |
