The ICUSB2321X Professional grade USB Serial Adapter cable converts a USB 2.0 port into an RS232 serial port allowing you to connect to, monitor and control your serial devices. A durable, single cable design makes this the perfect solution for mobile technicians/administrators that require serial connectivity. Once connected, the USB to serial adapter retains assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. This innovative adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to more modern computers, or computers with unused USB ports - perfect for connecting serial modems, barcode scanners or any device with serial sync through USB, eliminating the expense of upgrading the serial peripheral for USB compatibility.
- StarTech.com USB to Serial Adapter - 1 Port - COM Port Retention - Texas Instruments TIUSB3410 - USB to RS232 Adapter Cable (ICUSB2321X) - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 3.5 cm 1.3 cm
- Length
- 42 cm
- 33 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 920 Kbps
- Black
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 32-bit Edition
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 920 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 3.5 cm
- 1.3 cm
- Length
- 42 cm
- 33 g
- Limited warranty - 2 years
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £20.31 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £31.08 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £19.03 |
