Add a 10/100/1000Mbps Ethernet port to any PC through a PCI Express slot. The ST1000SPEX2 PCIe Gigabit Ethernet Network Card adds a 10/100/1000 Mbps compatible RJ45 Ethernet port to a PCI Express-enabled client, server or workstation, providing a convenient addition or replacement networking interface.
Compliant with IEEE 802.3/u/ab standards, and with support for 9K Jumbo Frames, VLAN tagging and Wake on LAN (WOL), this versatile Gigabit NIC/Server Adapter delivers rock-solid performance.
Plus, the card includes both full profile and low profile/half-height installation brackets for installation in a wide range of computer/server chassis, regardless of form factor.
- StarTech.com 1 Port PCIe Gigabit Network Server Adapter NIC Card - Dual Profile - Gigabit Desktop Adapter REV E Intel 6 Chip support (ST1000SPEX2) - network adapter - PCIe - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- Gigabit Ethernet
- 2 cm x 12 cm x 8 cm
- 36 g
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- Processor
- 1 x Realtek Semiconductor RTL8111E RTL8111E
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- 2-year warranty
- Designed For
- P/N: ET91000SM10, ET91000SM20
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- 1 Gbps
- Status Indicators
- Link/activity
- Full duplex capability, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- OS Required
- 2 cm
- 12 cm
- 8 cm
- 36 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 90%
- Designed For
StarTech.com 10' Cat5e Patch Cable Black | In Stock | £3.33 |
StarTech.com 15 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable | In Stock | £4.55 |
StarTech.com 10 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable | In Stock | £3.85 |
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card | In Stock | £10.71 |
StarTech.com 10ft Blue Cat5 UTP Patch Cable | In Stock | £3.32 |
StarTech.com 6ft Blue Cat5e UTP Patch Cable | In Stock | £2.76 |
StarTech.com 1 Port PCI 10/100/1000 32 Bit Gigabit Ethernet Network Adapter Card | In Stock | £8.59 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £122.85 |
StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile | In Stock | £15.00 |
StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile | In Stock | £14.78 |
