StarTech.com 1 Port PCI Express IDE Controller Adapter Card
Quicklinx: 5CBHWS00 Mfr#: PEX2IDE
Type: Storage controller
Controller Interface: IDE
Interface: PCI Express x1
Compatibility: PC
Hurry, only 3 left in stock!
£14.94 ex VAT
£17.92 inc VAT
This PCI Express IDE Controller Adapter Card provides a cost-effective way to use legacy drives with modern computers, by converting a PCI Express port into an IDE port.
Providing data burst transfer rates of up to 133MBps and support for PIO 0/1/2/3/4 and UDMA 33/66/100/133 operating modes, the IDE controller card offers an efficient way to add an IDE channel with support for two IDE drives on the same channel.
A complete dual profile solution, the PCI Express IDE controller card provides both standard and low profile brackets for adapting to slimline or small form factor system applications.
StarTech.com 1 Port PCI Express IDE Controller Adapter Card - Storage controller - ATA - 133 MBps - PCIe x1 - PEX2IDE - storage controller - ATA - PCIe x1
Storage controller - plug-in card
Bus Type
PCIe x1
ATA
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
Host Bus
PCIe x1
Storage Controller
ATA
Data Transfer Rate
133 MBps
Supported Devices
Hard drive
1 x ATA (internal)
Compatible Slots
1 x PCI Express x1
1 x IDE cable - internal - 46 cm
FCC, RoHS
Limited warranty - lifetime
Compatibility: PC
Price Range Ex VAT: 0 - 50
