This PCI Express IDE Controller Adapter Card provides a cost-effective way to use legacy drives with modern computers, by converting a PCI Express port into an IDE port.
Providing data burst transfer rates of up to 133MBps and support for PIO 0/1/2/3/4 and UDMA 33/66/100/133 operating modes, the IDE controller card offers an efficient way to add an IDE channel with support for two IDE drives on the same channel.
A complete dual profile solution, the PCI Express IDE controller card provides both standard and low profile brackets for adapting to slimline or small form factor system applications.
Efficient data transfer
The IDE controller provides a data transfer rate of 133 MBps, ensuring quick access to stored data. -
Simple installation
The plug-in card form factor allows for straightforward installation in a PCI Express x1 slot, making upgrades hassle-free. -
Robust compatibility
This storage controller is compatible with various hard drives that utilize the ATA interface, broadening its usability. -
Regulatory compliant
Meets FCC and RoHS standards, ensuring that the device adheres to environmental and safety regulations.
- StarTech.com 1 Port PCI Express IDE Controller Adapter Card - Storage controller - ATA - 133 MBps - PCIe x1 - PEX2IDE - storage controller - ATA - PCIe x1
- Storage controller - plug-in card
- Bus Type
- PCIe x1
- Interface
- ATA
- Data Transfer Rate
- 133 MBps
- Supported Devices
- Hard drive
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP, Windows 10 (32/64 bits)
- Limited lifetime warranty
- Host Bus
- PCIe x1
Storage Controller
- Interface
- ATA
- 133 MBps
- Supported Devices
- Hard drive
- 1 x ATA (internal)
- Compatible Slots
- 1 x PCI Express x1
- Cables Included
- 1 x IDE cable - internal - 46 cm
- FCC, RoHS
- OS Required
- Limited warranty - lifetime
