StarTech.com 1 Port PCI Express eSATA II Controller Card
Quicklinx: 5D41WS00 Mfr#: PEXESATA1
Add an eSATA port to a desktop computer through a PCI Express slot. This eSATA Controller Card turns a PCI Express (1x) slot into an external SATA port, to provide a quick and hassle-free external storage solution.
Supporting SATA 300 (SATA II) hard drives (backward compatible with SATA /150) and data transfer rates of up to 3Gbps, this PCI Express eSATA Controller Card is the perfect solution for upgrading existing eSATA capability, or simply adding an external SATA port to a PC desktop computer.
Using a native PCI Express single chipset, the controller card provides enhanced compatibility, reliability and performance for your external storage needs. The controller card also features port multiplier support with command based switching for connecting multiple external hard drives to a host computer through one eSATA connection.
The PCI Express eSATA Controller Card also features an internal SATA port, which could be used for a conventional (internal) SATA drive installation. Please note that the internal SATA port can not be used at the same time as the external SATA port.
StarTech.com 1 Port PCI Express eSATA Controller Card - storage controller - SATA 3Gb/s / eSATA 3Gb/s - PCIe x1
Storage controller - plug-in card
Bus Type
PCIe x1
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Microsoft Windows Vista / 2000 / XP
P/N: S3540BU33E, SATDOCK4U3RE, SATDOCK5U3ER, SDOCKU33EBV
Host Bus
PCIe x1
Storage Controller
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1 x eSATA 3Gb/s - eSATA (external) , 1 x SATA 3Gb/s - SATA (internal)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Limited warranty - lifetime
