StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card
Quicklinx: 5FFZWS00 Mfr#: PEX100S
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£17.56 ex VAT
£21.07 inc VAT
This PCI Express based 10/100 Ethernet Card provides a simple way to connect a PCIe enabled server or workstation to a 10/100 Ethernet network and offers a broad range of features and functions, including support for both Full and Half Duplex operation as well as Wake On LAN (WOL) Power Management.
The PEX100S Ethernet Card includes both standard and low profile brackets and is compatible with most mATX (Slimline) and ATX system form factors, and features Auto MDI/MDIX automatic configuration, which helps to simplify installation and configuration.
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card (PEX100S) - network adapter - PCIe - 10/100 Ethernet
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
10/100 Ethernet
2.1 cm x 12 cm
45 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
1 x Realtek Semiconductor RTL8101E
IEEE 802.3x
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
Network adapter
PCI Express x1
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
Status Indicators
Port transmission speed
Full duplex capability, auto-sensing per device, auto-negotiation, WOL, auto-uplink (auto MDI/MDI-X), half duplex mode
IEEE 802.3x
Processor / Memory
1 x 100Base-TX - RJ-45
Compatible Slots
1 x PCI Express x1
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
2.1 cm
12 cm
45 g
Limited warranty - lifetime
5FFZ StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £19.19
5FFZ StarTech.com Dual Port Gigabit PCI Express Server Network Adapter Card - PCIe NIC In Stock £82.16
5FFZ StarTech.com 4-Port Gigabit NIC - PCIe In Stock £159.44
5FFZ StarTech.com 4-Port PCIe Gigabit NIC In Stock £124.18
Protocol: Ethernet
Compatibility: PC
