StarTech.com 1-Port Parallel PCIe Card, PCI Express to Parallel DB25 LPT
Quicklinx: G8L1WS00 Mfr#: PEX1P2
Wired / Wireless: Wired
Protocol: Parallel
Form Factor: Plug-in card
Compatibility: [N/A], Unix
Type: Parallel adapter
14 In Stock
£20.34 ex VAT
£24.40 inc VAT
PCI Express 2.0 LPT PCIe 1x Slot 2.5 Mbps Lifetime Warranty. This PCIe Parallel controller card installs into an available PCI-Express x1 slot in your computer and enables you to add DB25 parallel communication port to your system.
Adds a Parallel Port to Your Desktop Computer
The controller card features an Asix AX99100 chip and enables you to connect a DB25 device to your desktop computer. The parallel port port is ideal for connecting printers, scanners, plotters, point-of-sale terminals, PLCs, scientific sensors, medical equipment or oscilloscopes. The card can also be used in factories, to control or automate equipment. The parallel (LPT) port supports SPP/Byte/Nibble/ECP modes and is compatible with PCI Power Management 1.2 and IEEE 1284 for speeds up to 2.5Mbps.
Wide Installation Compatibility
This add-on card includes both full-profile and low-profile installation brackets (full-profile bracket pre-installed) ensuring you can install it into either a full or low-profile PCIe 2.0 x1 slot (backward compatible with PCIe 1.1). For wide platform support the card is compatible with Windows (XP or higher), Windows Server (2003 or higher), and Linux (2.6.X or higher).
PEX1P2 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Adds a parallel port to your desktop computer
    The controller card features an Asix AX99100 chip and enables you to connect a DB25 device to your desktop computer. The parallel port is ideal for connecting printers, scanners, plotters, point-of-sale terminals, PLCs, scientific sensors, medical equipment or oscilloscopes. The card can also be used in factories, to control or automate equipment. The parallel (LPT) port supports SPP/Byte/Nibble/ECP modes and is compatible with PCI Power Management 1.2 and IEEE 1284 for speeds up to 2.5Mbps.
  • Wide installation compatibility
StarTech.com 1-Port Parallel PCIe Card, PCI Express to Parallel DB25 LPT Adapter Card, Desktop Expansion Controller for Printer, SPP/ECP - parallel adapter - PCIe - IEEE 1284
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 2.0
Ports
IEEE 1284
7.3 cm x 12 cm x 1.85 cm
45 g
Parallel
Data Transfer Rate
2.5 Mbps
ASIX AX99100
Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows 2003, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019
Parallel adapter
Plug-in card
PCI Express
PCIe 2.0
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
2.5 Mbps
Processor / Memory
ASIX AX99100
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Low-profile bracket
MTBF
17,520 hours
FCC, RoHS, WEEE, RCM
7.3 cm
12 cm
1.85 cm
45 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
290 g
5 °C
50 °C
40 - 80%
G8L1 StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £39.11
G8L1 StarTech.com Serial/Parallel PCI Card In Stock £19.87
Protocol: Parallel
Compatibility: Unix
