The StarTech.com 1-Port Gigabit PCIe Network Adapter Card enhances connectivity with a data transfer rate of 1 Gbps. This plug-in card supports various Ethernet cabling types, ensuring compatibility with different network setups. With a maximum operating temperature of 70°C and the ability to handle a humidity range of 10% to 80%, it performs reliably in various environments.
Featuring functionalities such as Wake On LAN (WOL), auto-negotiation, and Automatic Media-Dependent Interface Crossover (MDIX), this network adapter provides convenience and flexibility for users. It meets compliance standards including RoHS and IEEE specifications, making it a responsible choice for environmentally aware consumers. Its low-profile design allows for easy installation in compact spaces.
Efficient Jumbo frame support
The adapter supports Jumbo frame sizes up to 9000, allowing for larger data packets, which can improve network efficiency and performance, especially in high-traffic environments. -
Robust environmental reliability
With an operational temperature range between 5°C and 70°C and a humidity tolerance of 10% to 80%, this network adapter is designed to function reliably in diverse conditions. -
High-speed wired connectivity
Offering a data transfer rate of 1 Gbps and supporting multiple Ethernet standards, this network adapter ensures fast and stable connections for data-intensive applications. -
Advanced features for flexibility
Equipped with features like auto-negotiation and Automatic Media-Dependent Interface Crossover (MDIX), this adapter provides seamless adaptation between different network configurations. -
Compliance with important standards
This product is compliant with various industry standards such as RoHS, WEEE, and several IEEE protocols, ensuring environmentally friendly and reliable performance in network environments.
- StarTech.com 1-Port Gigabit PCIe Network Adapter Card, TAA Compliant - network adapter - PCIe - Gigabit Ethernet x 1 - TAA Compliant
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- 1.8 cm x 6.5 cm x 4.2 cm
- 34 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- 1 x Realtek Semiconductor RTL8111H
- IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
- Black
- System Requirements
- Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Windows 8 / 10 / 11, Linux 2.4.x or later (LTS versions only)
- TAA Compliant
- 2-year warranty
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Capacity
- Status Indicators
- Link/activity, port transmission speed
- WOL, auto-negotiation, Auto MDIX, promiscuous mode
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45
- Included Accessories
- Half-height bracket
- RoHS, WEEE, Plug and Play, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
- Black
- TAA Compliant
- OS Required
- 1.8 cm
- 6.5 cm
- 4.2 cm
- 34 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 100.5 g
- Limited warranty - 2 years
- 5 °C
- 70 °C
- 10 - 80% (non-condensing)
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £206.76 |
StarTech.com 1-Port Network Card, TAA | In Stock | £22.01 |
StarTech.com 2-Port Network Card, TAA | In Stock | £85.84 |
