Efficient performance
With a data transfer rate of 1 Gbps, this network adapter ensures efficient and fast connections, delivering the necessary bandwidth for demanding tasks. -
Versatile compatibility
The network adapter is compliant with a variety of standards including IEEE 802.3 and RoHS, ensuring compatibility with a wide range of devices and systems. -
Convenient installation
Featuring a Plug-and-Play design, the adapter allows for quick and easy setup without the need for complex configurations or additional software. -
Robust design
The adapter supports an operating temperature range from 5°C to 70°C, making it suitable for diverse environmental conditions and ensuring reliability in various setups. -
Advanced features
Equipped with functionalities such as Wake On LAN and Automatic Media-Dependent Interface Crossover, this adapter offers enhanced connectivity options and simplifies network management.
- StarTech.com 1-Port Gigabit PCIe Network Adapter Card, TAA Compliant - network adapter - PCIe - Gigabit Ethernet x 1 - TAA Compliant
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- 1.8 cm x 6.5 cm x 4.2 cm
- 34 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- 1 x Realtek Semiconductor RTL8111H
- IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
- Black
- System Requirements
- Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Windows 8 / 10 / 11, Linux 2.4.x or later (LTS versions only)
- TAA Compliant
- 2-year warranty
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Capacity
- Status Indicators
- Link/activity, port transmission speed
- WOL, auto-negotiation, Auto MDIX, promiscuous mode
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45
- Included Accessories
- Full-height bracket
- RoHS, WEEE, Plug and Play, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
- Black
- TAA Compliant
- OS Required
- 1.8 cm
- 6.5 cm
- 4.2 cm
- 34 g
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 100.5 g
- Limited warranty - 2 years
- 5 °C
- 70 °C
- 10 - 80% (non-condensing)
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £206.76 |
StarTech.com 1-Port Network Card, TAA | In Stock | £22.69 |
StarTech.com 2-Port Network Card, TAA | In Stock | £85.84 |
