The StarTech.com 1-Port 5G Gigabit PCIe Network Adapter Card enhances networking capabilities with features and data transfer rates. Designed to support various Ethernet protocols like 5 Gigabit Ethernet, this card offers a solution for wired connectivity that meets requirements. With a data transfer rate of 5 Gbps and support for jumbo frames up to 9 KB, this adapter ensures smooth and efficient data handling for home or office use.
Operating within a temperature range from 5°C to 65°C and with humidity tolerance from 10% to 80% (non-condensing), the network adapter is built to perform reliably in various environments. Features such as Wake On LAN (WOL), PXE support, and Automatic Media-Dependent Interface Crossover (MDIX) further enhance its utility, making it suitable for both professional networks and individual users seeking connectivity options.
Reliable performance
This network adapter operates within a temperature range of 5°C to 65°C, ensuring dependable connectivity in diverse environments. -
High data transfer rates
Capable of supporting data transfer rates up to 5 Gbps, this adapter meets the demands of high-speed networking applications. -
Versatile protocol support
The adapter supports various Ethernet standards, including IEEE 802.3 and IEEE 802.3bz, making it suitable for multiple network configurations. -
Effective connectivity features
Features such as Wake On LAN (WOL) and Automatic Media-Dependent Interface Crossover (MDIX) enhance the adapter's performance and ease of use. -
Compact design
The low-profile design of this plug-in card allows it to fit in a variety of computer cases, enabling flexible installation.
- StarTech.com 1-Port 5G Gigabit PCIe Network Adapter Card, TAA Compliant - network adapter - PCI Express 3.1 x1 - 5GBase-T x 1 - TAA Compliant
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Specification Revision
- PCIe 3.1
- Ports
- 5GBase-T x 1
- 1.8 cm x 12 cm x 7.2 cm
- 40.5 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE, 5GbE
- Data Transfer Rate
- 5 Gbps
- Capacity
- Jumbo frame size: 9 KB
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3ab, IEEE 802.3az, IEEE 802.3bz, IEEE 802.1Qav, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1ad
- Black
- System Requirements
- Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Ubuntu Linux 20.04 or later
- TAA Compliant
- 2-year warranty
- Network adapter
- Form Factor
- PCIe 3.1
- Ports
- 5GBase-T x 1
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet
- 5 Gbps
- Capacity
- Status Indicators
- Link/activity/speed
- Auto MDIX, promiscuous mode, PXE support, WOL, bus powered
- 1 x 1/2.5/5GBase-T - RJ-45
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Black
- TAA Compliant
- OS Required
- 1.8 cm
- 12 cm
- 7.2 cm
- 40.5 g
- Limited warranty - 2 years
- 5 °C
- 65 °C
- 10 - 80% (non-condensing)
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £211.09 |
