StarTech.com 1-Port Network Card, TAA
Quicklinx: J7Y0WS00 Mfr#: PR15GR-NETWORK-CARD
£39.79 ex VAT
£47.74 inc VAT
The StarTech.com 1-Port 5G Gigabit PCIe Network Adapter Card enhances networking capabilities with features and data transfer rates. Designed to support various Ethernet protocols like 5 Gigabit Ethernet, this card offers a solution for wired connectivity that meets requirements. With a data transfer rate of 5 Gbps and support for jumbo frames up to 9 KB, this adapter ensures smooth and efficient data handling for home or office use.
Operating within a temperature range from 5°C to 65°C and with humidity tolerance from 10% to 80% (non-condensing), the network adapter is built to perform reliably in various environments. Features such as Wake On LAN (WOL), PXE support, and Automatic Media-Dependent Interface Crossover (MDIX) further enhance its utility, making it suitable for both professional networks and individual users seeking connectivity options.
  • Reliable performance
    This network adapter operates within a temperature range of 5°C to 65°C, ensuring dependable connectivity in diverse environments.
  • High data transfer rates
    Capable of supporting data transfer rates up to 5 Gbps, this adapter meets the demands of high-speed networking applications.
  • Versatile protocol support
    The adapter supports various Ethernet standards, including IEEE 802.3 and IEEE 802.3bz, making it suitable for multiple network configurations.
  • Effective connectivity features
    Features such as Wake On LAN (WOL) and Automatic Media-Dependent Interface Crossover (MDIX) enhance the adapter's performance and ease of use.
  • Compact design
    The low-profile design of this plug-in card allows it to fit in a variety of computer cases, enabling flexible installation.
StarTech.com 1-Port 5G Gigabit PCIe Network Adapter Card, TAA Compliant - network adapter - PCI Express 3.1 x1 - 5GBase-T x 1 - TAA Compliant
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.1 x1
PCI Specification Revision
PCIe 3.1
Ports
5GBase-T x 1
1.8 cm x 12 cm x 7.2 cm
40.5 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE, 5GbE
Data Transfer Rate
5 Gbps
Jumbo frame size: 9 KB
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3ab, IEEE 802.3az, IEEE 802.3bz, IEEE 802.1Qav, IEEE 802.1p, IEEE 802.1Q, IEEE 802.1ad
Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Ubuntu Linux 20.04 or later
TAA Compliant
Network adapter
PCI Express 3.1 x1
PCIe 3.1
Ports
5GBase-T x 1
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet
Data Transfer Rate
5 Gbps
Status Indicators
Link/activity/speed
Auto MDIX, promiscuous mode, PXE support, WOL, bus powered
1 x 1/2.5/5GBase-T - RJ-45
Low-profile bracket
FCC, RoHS
TAA Compliant
1.8 cm
12 cm
7.2 cm
40.5 g
5 °C
65 °C
10 - 80% (non-condensing)
J7Y0 StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £211.09
