StarTech.com 1-Port Network Card, TAA
Quicklinx: J1KVWS00 Mfr#: ST1000SPEX2T
£20.95 ex VAT
£25.14 inc VAT
The StarTech.com 1-Port Gigabit PCIe Network Adapter Card enhances connectivity with a data transfer rate of 1 Gbps. This plug-in card supports various Ethernet cabling types, ensuring compatibility with different network setups. With a maximum operating temperature of 70°C and the ability to handle a humidity range of 10% to 80%, it performs reliably in various environments.
Featuring functionalities such as Wake On LAN (WOL), auto-negotiation, and Automatic Media-Dependent Interface Crossover (MDIX), this network adapter provides convenience and flexibility for users. It meets compliance standards including RoHS and IEEE specifications, making it a responsible choice for environmentally aware consumers. Its low-profile design allows for easy installation in compact spaces.
  • Efficient Jumbo frame support
    The adapter supports Jumbo frame sizes up to 9000, allowing for larger data packets, which can improve network efficiency and performance, especially in high-traffic environments.
  • Robust environmental reliability
    With an operational temperature range between 5°C and 70°C and a humidity tolerance of 10% to 80%, this network adapter is designed to function reliably in diverse conditions.
  • High-speed wired connectivity
    Offering a data transfer rate of 1 Gbps and supporting multiple Ethernet standards, this network adapter ensures fast and stable connections for data-intensive applications.
  • Advanced features for flexibility
    Equipped with features like auto-negotiation and Automatic Media-Dependent Interface Crossover (MDIX), this adapter provides seamless adaptation between different network configurations.
  • Compliance with important standards
    This product is compliant with various industry standards such as RoHS, WEEE, and several IEEE protocols, ensuring environmentally friendly and reliable performance in network environments.
StarTech.com 1-Port Gigabit PCIe Network Adapter Card, TAA Compliant - network adapter - PCIe - Gigabit Ethernet x 1 - TAA Compliant
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
Ports
1.8 cm x 6.5 cm x 4.2 cm
34 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
1 x Realtek Semiconductor RTL8111H
IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Windows 8 / 10 / 11, Linux 2.4.x or later (LTS versions only)
TAA Compliant
Network adapter
PCI Express x1
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity, port transmission speed
WOL, auto-negotiation, Auto MDIX, promiscuous mode
Processor / Memory
1 x 1000Base-T - RJ-45
Half-height bracket
RoHS, WEEE, Plug and Play, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3x
TAA Compliant
1.8 cm
6.5 cm
4.2 cm
34 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
100.5 g
5 °C
70 °C
10 - 80% (non-condensing)
J1KV StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £284.02
J1KV StarTech.com 1-Port Network Card, TAA In Stock £21.83
J1KV StarTech.com 2-Port Network Card, TAA In Stock £82.35
J1KV StarTech.com 1-Port Network Card, TAA In Stock £39.79
