This PCI Express RS232 Serial adapter card adds an RS232 (DB9) Serial Port to a computer through an available PCI Express slot, while relying on a native, single-chip design (Oxford OXPCIe952) that harnesses the capability of true PCI Express - ensuring maximum performance and reliability and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
Compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, and Linux Kernel 2.6.11 and up, the PEX1S952 PCI Express Serial Card also features an optional half-height/low profile bracket that allows the card to be installed in virtually any computer case, regardless of the case form factor.
- StarTech.com 1 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter - PCIe - RS-232
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- RS-232
- 6.5 cm x 9 cm x 2 cm
- 48 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows 2000, Apple MacOS X 10.4 or later, SuSE Linux Kernel 2.6.x, Microsoft Windows 2003, Microsoft Windows Vista / XP
- 2-year warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 1.0a
- Bus Voltage
- 3.3 V
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 6.5 cm
- 9 cm
- 2 cm
- 48 g
- Limited warranty - 2 years
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
