Add a high-speed RS-232 Serial port to your computer through a PCI Express expansion slot.
The PEX1S553 PCI Express Serial adapter card allows you to turn a PCI Express slot into an RS232 (DB9) serial connection. The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express (RS232) Serial Adapter Card is compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista /Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS X 10.4 and above. The adapter card includes an optional half-height/low profile bracket, that lets you add a serial port to virtually any computer, regardless of the case form factor.
This product is a replacement for the PEX1S552 card.
- StarTech.com 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter - PCIe - RS-232
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- Ports
- RS-232
- 12 cm x 10.5 cm x 2 cm
- Cabling Type
- Serial RS-232
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.x, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express
- Ports
- RS-232
- Connectivity Technology
- Wired
- Cabling Type
- Serial RS-232
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI Express
- FCC, RoHS
- OS Required
- 12 cm
- 10.5 cm
- 2 cm
- -20 °C
- 85 °C
- 5 - 85%
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
