Add a parallel port to your low profile/small form factor computer through a PCI expansion slot. The PCI1P LP 1 Port Low Profile PCI Parallel Adapter Card adds one IEEE 1284 port to your small form factor PC, with data transfer speeds of up to 2.7 Mbps - up to 3 times faster than on-board parallel ports. The adapter card features a low profile design that is suited to small form factor computer cases, while including a full height bracket to adapt to any installation.
Installation is a breeze with plug and play support and drivers for Windows 7, Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux . IRQ sharing and hot swapping capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
- StarTech.com 1 Port Low Profile PCI Parallel Adapter Card - Parallel adapter - PCI low profile - IEEE 1284 - PCI1P_LP - parallel adapter - PCI - IEEE 1284
- Parallel adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI
- Ports
- IEEE 1284
- Data Link Protocol
- Parallel
- Data Transfer Rate
- 1.5 Mbps
- System Requirements
- Microsoft DOS, Microsoft Windows 95/98, Linux, Microsoft Windows Millennium Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Parallel adapter
- Form Factor
- PCI
- Ports
- IEEE 1284
- Connectivity Technology
- Wired
- Parallel
- 1.5 Mbps
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 1
- Compatible Slots
- 1 x PCI - low-profile
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - lifetime
Customer reviews
Write a review for the StarTech.com 1 Port Low Profile PCI Parallel Adapter Card here!
Fit & Forget
Reviewed by Anonymous Review Posted 09/09/2008
Not the cheapest of cards but, if you want reliability, worth the little extra.
Easy configuration. Just Fit & Forget.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
