StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART
Quicklinx: 76T1WS00 Mfr#: PEX1S553LP
Type: Serial adapter
Compatibility: PC
Interface: PCI Express
  • Windows 8 (32/64 bits)
£34.08 ex VAT
£40.89 inc VAT
The PEX1S553LP PCI Express serial card turns a PCI Express slot into an RS232 (DB9) serial connection. The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express RS232 serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista /Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and ships with a low profile/half-height bracket installed, but includes an optional full profile bracket that lets you add a serial port to virtually any computer (regardless of the case form factor). This product is a replacement for the PEX1S552LP card.
StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART (PEX1S553LP) - serial adapter - PCIe - RS-232
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232
RS-232
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.4 - 10.7, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
PCI Express
Ports
RS-232
Wired
RS-232
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
WHQL, FCC
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
76T1 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
76T1 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
76T1 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
76T1 StarTech.com 1-Prt PCI Express Serial Card In Stock £36.98
76T1 StarTech.com PCIe Dual Serial Port Card In Stock £42.80
Compatibility: PC
