Deliver power and data to your Power over Ethernet device using this mountable PoE+ midspan. This Gigabit Power over Ethernet (PoE+) injector supplies power and data connectivity to a Gigabit PoE-compliant device using standard Ethernet cable, at distances of up to 100 m (330 ft.).
The PoE midspan is a cost-effective alternative to upgrading your existing network switch to a PoE-capable model.
This versatile PoE injector lets you connect a PoE-powered device (PD) to a non-PoE network switch, so you can avoid the expense and aggravation of replacing your existing switch with a PoE-enabled model. It supplies up to 30 watts of power, so you can easily power and access a high-power PoE-compliant device, such as an IP camera or a wireless access point (WAP), using traditional copper (RJ45) Ethernet cable. The midspan injector makes it easy to extend data and power connectivity to your PoE+ device across long distances, even in a remote location where a typical power outlet isn't available.
You can integrate this compact injector discreetly into a variety of environments. It features a surface-mountable housing that's perfect for installing on walls or under a desk, but it's also palm-sized, for use on desktop surfaces.
Plus, with plug-and-play operation, you can enjoy fast and hassle-free setup without disrupting your workflow.
Not sure which class your PoE device is? The Gigabit PoE+ injector automatically detects the power requirements of your connected PoE PD, and delivers the appropriate level of power without damaging your device.
- StarTech.com 1 Port Gigabit Midspan - PoE+ Injector - 802.3at and 802.3af - Wall-Mountable Power over Ethernet Injector Adapter (POEINJ1G) - PoE injector - 30 Watt
- PoE injector - external
- 55 g
- Localisation
- North America, United Kingdom, Europe
- Output Voltage
- 48 V
- Power Capacity
- 30 Watt
- Output connectors
- 1 x RJ-45
- Black
- 4.5 cm x 7 cm x 2.5 cm
- 2-year warranty
- Designed For
- P/N: POEEXT1GAT, POEEXT2GAT, ST12MHDLANU
- Black
- Localisation
- Input Voltage Range
- AC 100 - 240 V
- Power Output Connectors Details
- 1 x RJ-45
- Output Voltage
- 48 V
- Max Electric Current
- 0.75 A
- Power Capacity
- 30 Watt
- 1 x Gigabit LAN - RJ-45
- Wall mountable
- FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- 4.5 cm
- 7 cm
- 2.5 cm
- 55 g
- Designed For
