StarTech.com 1-Port Gigabit NIC - PCIe
Quicklinx: BJX3WS00 Mfr#: ST1000SPEXI
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
More than 50 In Stock
£27.80 ex VAT
£33.36 inc VAT
Add Gigabit Ethernet to a client, server or workstation through a PCI Express slot. Boost the performance and capabilities of your server or desktop computer by adding a Gigabit Ethernet port through a PCI Express slot, to help deliver a high-performance and cost-effective network solution.
This Gigabit Ethernet network card utilizes the Intel I210-AT chipset, designed to deliver the power, performance and enhanced capabilities you need for dependable network connections to your server or computer. Compliant with IEEE 802.3/u/ab standards, the network card provides an effective upgrade or replacement network port with maximum throughput up to 1000Mbps in each direction (2000 Mbps total) - up to ten times faster than 10/100 Ethernet.
The I210 chipset provides many advanced features to support load-balancing the flow of network traffic, to enhance throughput and provide greater data reliability. It also supports Audio-Video Bridging (AVB) to enable tightly controlled media stream synchronization, buffering and resource reservation.
Compatible with a broad range of operating systems, this versatile PCIe Gigabit NIC is ideal for many business applications requiring upgrades to servers or workstations, adding feature-rich Gigabit networking. It's a cost-effective way to upgrade your server or computer from a 10/100 Ethernet port to a Gigabit Ethernet port, or add an Ethernet port to take advantage of advanced features such as VLAN tagging, Jumbo Frames, Wake-On LAN and Auto MDIX.
With a dual-profile design, the PCI Express network card installs easily into a wide range of computer/server chassis, regardless of form factor. The card comes equipped with a full-sized bracket, and includes a low profile/half-height installation bracket that you can use as needed.
  • Versatile compatibility
    This network card is compatible with Unix systems, providing flexibility for various networking environments.
  • High-performance data transfer
    Achieving a data transfer rate of 1 Gbps ensures efficient and fast connectivity for applications that demand speed.
  • Robust environmental resilience
    Designed to operate between 5 °C and 50 °C, this network card can withstand a range of temperatures for reliable performance.
  • Sleek low-profile design
    The low-profile form factor allows for easy installation within compact computer cases without compromising performance.
  • Enhanced functionality
    Featuring auto-uplink capability and support for Jumbo frames, this adapter provides reliable and efficient network performance.
StarTech.com 1-Port Gigabit Ethernet Network Card - PCI Express, Intel I210 NIC - Single Port PCIe Network Adapter Card with Intel Chipset (ST1000SPEXI) - network adapter - PCIe
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
6.6 cm x 12 cm x 1.8 cm
35 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
1GbE
Data Transfer Rate
1 Gbps
Performance
Forwarding performance (full duplex): 2 Gbps
Jumbo frame size: 9000
Intel I210-AT
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Network adapter
PCI Express x1
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Performance
Status Indicators
Port status, link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
Processor / Memory
Intel I210-AT
1 x network - RJ-45
Low-profile bracket
FCC, RoHS
0.8 Watt
6.6 cm
12 cm
1.8 cm
35 g
5 °C
50 °C
20 - 80%
BJX3 StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £205.95
BJX3 StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £18.28
BJX3 StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile In Stock £18.28
BJX3 StarTech.com 4-Port Gigabit NIC - PCIe In Stock £148.13
BJX3 StarTech.com 1-Port Gigabit NIC - PCIe In Stock £27.80
BJX3 StarTech.com 1-Port 10GbE NIC - PCI Express In Stock £243.57
BJX3 StarTech.com 10G PCIe Network Adapter Card In Stock £124.73
BJX3 StarTech.com 10G PCIe Network Adapter Card In Stock £120.03
BJX3 StarTech.com 2-Port 2.5G PCIe Network Card In Stock £121.39
BJX3 StarTech.com 4-Port 2.5G PCIe Network Card In Stock £154.44
Compatibility: PC
Compatibility: Unix
