Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
- StarTech.com USB to Serial Adapter - Optical Isolation - USB Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter Cable (ICUSB2321FIS) - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- 4.2 cm x 4.5 cm x 2.2 cm
- 150 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Processor
- FTDI FT232RL
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 2500V isolation, USB powered, plastic housing
Processor / Memory
- Processor
- FTDI FT232RL
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB cable (integrated) - 1.8 cm
- WHQL, FCC, RoHS
- Black
- OS Required
- 4.2 cm
- 4.5 cm
- 2.2 cm
- 150 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.75 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £33.25 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £15.32 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.33 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £49.60 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.05 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £102.11 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £177.69 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.35 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £79.29 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £244.59 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £392.42 |
StarTech.com 3ft/1m USB to Serial Cable | In Stock | £38.43 |
StarTech.com 10ft/3m USB to RS232 Serial Adapter | In Stock | £47.21 |
