Brand
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation
Quicklinx: 7VXHWS00 Mfr#: ICUSB2321FIS
Hurry, only 1 left in stock!
£103.20 ex VAT
£123.84 inc VAT
Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
StarTech.com USB to Serial Adapter - Optical Isolation - USB Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter Cable (ICUSB2321FIS) - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
4.2 cm x 4.5 cm x 2.2 cm
150 g
RS-232
Data Transfer Rate
921.6 Kbps
FTDI FT232RL
Linux, Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
2500V isolation, USB powered, plastic housing
Processor / Memory
FTDI FT232RL
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.8 cm
WHQL, FCC, RoHS
4.2 cm
4.5 cm
2.2 cm
150 g
55 °C
5 - 95%
7VXH StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £20.99
7VXH StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.74
7VXH StarTech.com 2 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £47.49
7VXH StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £14.36
7VXH StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £21.54
7VXH StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £47.92
7VXH StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £103.20
7VXH StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £24.12
7VXH StarTech.com USB to RS232 Serial Adapter In Stock £15.45
7VXH StarTech.com 8-Port USB to Serial Adapter In Stock £382.87
Stock Status: In stock
