StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation
Quicklinx: 7VXHWS00 Mfr#: ICUSB2321FIS
Length: 2.4m
£92.00 ex VAT
£110.40 inc VAT
Add an RS232 Serial Port with Circuit Isolation to your Laptop or Desktop Computer, through USB. The ICUSB2321FIS 1-Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation converts an available USB 1.1 or 2.0 port into an RS232 DB9 port that can be used to connect, monitor and control your serial devices. The USB to serial adapter features integrated optical isolation circuits and surge protection to protect your critical, sensitive control equipment against electrical damage, making it a viable solution for costly industrial serial devices. The versatile FTDI chipset also supports COM retention, additional customization/features, and compatibility not offered by most other solutions. Broad operating system compatibility including Windows, Windows CE, Mac OS and Linux, makes this product easy to integrate into mixed environments.
  • Robust construction
    The plastic housing of this adapter ensures durability, making it suitable for various work environments and applications.
  • Versatile compatibility
    Designed for Mac systems, the USB to Serial Adapter offers functionality across numerous devices requiring RS-232 connections.
  • Reliable performance
    With a maximum data transfer rate of 921.6 Kbps, this adapter ensures efficient communication for data-driven tasks.
  • Temperature resilience
    Operates effectively within a temperature range of 0°C to 55°C, providing reliability in a variety of settings.
  • Complete isolation
    The 2500V isolation feature protects data integrity and device functionality, offering a secure connection for sensitive environments.
StarTech.com USB to Serial Adapter - Optical Isolation - USB Powered - FTDI USB to Serial Adapter - USB to RS232 Adapter Cable (ICUSB2321FIS) - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
4.2 cm x 4.5 cm x 2.2 cm
150 g
RS-232
Data Transfer Rate
921.6 Kbps
FTDI FT232RL
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
2500V isolation, USB powered, plastic housing
Processor / Memory
FTDI FT232RL
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.8 cm
WHQL, FCC, RoHS
4.2 cm
4.5 cm
2.2 cm
150 g
55 °C
5 - 95%
7VXH StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.54
7VXH StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.44
7VXH StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £13.40
7VXH StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
7VXH StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £44.84
7VXH StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £92.00
7VXH StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
7VXH StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £89.71
7VXH StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £144.33
7VXH StarTech.com USB to RS232 Serial Adapter In Stock £15.88
7VXH StarTech.com 4 Port USB to Serial Hub In Stock £76.59
7VXH StarTech.com 4-Port USB to Serial Adapter In Stock £207.06
7VXH StarTech.com 8-Port USB to Serial Adapter In Stock £332.34
7VXH StarTech.com 3ft/1m USB to Serial Cable In Stock £30.87
7VXH StarTech.com 10ft/3m USB to RS232 Serial Adapter In Stock £37.61
7VXH StarTech.com 6.6ft/2m USB to Serial Adapter In Stock £27.27
Length: 2.4m
