StarTech.com 1 Port ExpressCard to RS232 DB9 Serial Adapter Card w/ 16950 - USB Based
Quicklinx: 8379WS00 Mfr#: EC1S232U2
Type: Serial adapter
Compatibility: Mac, PC
Interface: ExpressCard/34
Hurry, only 3 left in stock!
£23.94 ex VAT
£28.72 inc VAT
Add a USB-based RS232 Serial port to your laptop through an ExpressCard slot. The EC1S232U2 ExpressCard RS232 Serial Adapter Card (USB-based) (16950 UART) adds an RS232 (DB9) serial port to your ExpressCard-equipped laptop, enabling you to connect an RS232 serial peripheral device such as a plotter, digital signage device, receipt printer or bar code scanner through an available ExpressCard slot.
This USB-based ExpressCard supports RS232 serial data transfer rates up to 460 Kbps and eliminates the need to upgrade serial peripherals to more modern interfaces (e.g. USB, etc.) for the sake of host compatibility, saving both expense and hassle.
StarTech.com 1 Port ExpressCard to RS232 DB9 Serial Adapter Card USB Based - serial adapter
Serial adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
RS-232
3.5 cm x 11.5 cm x 1.8 cm
34 g
RS-232
Data Transfer Rate
460.8 Kbps
PL-2303 - Prolific
Apple MacOS 9.x, Apple MacOS 8.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2008
Serial adapter
Plug-in module
ExpressCard/34
Ports
RS-232
Wired
RS-232
Data Transfer Rate
460.8 Kbps
Processor / Memory
PL-2303 - Prolific
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x ExpressCard/34
FCC, RoHS
3.5 cm
11.5 cm
1.8 cm
34 g
Limited warranty - lifetime
57 °C
8379 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.84
8379 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
8379 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
8379 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
8379 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
8379 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 0 - 50
