Add an internal SATA port and an external SATA (eSATA) port to your desktop computer through a PCI expansion slot. This PCI based SATA Controller Card allows you to turn a PCI slot into one internal SATA and one external SATA (eSATA) connection. Supporting SATA 150 hard drives, and data transfer rates of up to 1.5Gbps, this controller card is the perfect solution if you need an extra SATA port or want to externalize your storage.
- StarTech.com 1 Port eSATA + 1 Port SATA PCI SATA Controller Card w/ LP BRacket - eSATA Controller - SATA II Controller (PCIESATA2I) - storage controller - SATA 1.5Gb/s / eSATA - PCI
- Storage controller - plug-in card - low profile
- Bus Type
- PCI
- Interface
- Data Transfer Rate
- 1.5 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows Vista / 2000 / XP
- 12.1 cm x 5.4 cm x 2 cm
- 47 g
- 2-year warranty
- Host Bus
- PCI
Storage Controller
- Interface
- 1.5 Gbit/s
- Supported Devices
- Hard drive
- Channel Qty
- 2
- 2
- Processor
- VIA VT6421
- 1 x SATA 1.5Gb/s - eSATA (external) , 1 x SATA 1.5Gb/s - SATA (internal)
- Compatible Slots
- 1 x PCI
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 12.1 cm
- 5.4 cm
- 2 cm
- 47 g
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
StarTech.com 8 Port SATA 6Gbps PCIe Card | In Stock | £82.07 |
StarTech.com 6-Port SATA PCIe Card - 6Gbps | In Stock | £60.79 |
StarTech.com 10-Port SATA PCIe Card - 6Gbps | In Stock | £95.95 |
StarTech.com SATA III RAID PCIe Card 2pt | In Stock | £44.80 |
StarTech.com SATA III PCIe Card - 2-Port | In Stock | £27.98 |
StarTech.com 4-Port SATA PCIe Card - 6Gbps | In Stock | £43.61 |
