Add an Ethernet port to a PC client, server or workstation supporting four network speeds: 5G/2.5G/1G/100Mbps. This 4-speed NBASE-T PCIe network card offers an inexpensive network upgrade solution, providing access to your network at multiple speeds up to 5G, using your existing Cat5e copper cabling.
Fully compliant with 2.5GBASE-T, 5GBASE-T, and NBASE-T (Draft IEEE802.3bz) specifications, the PCIe NIC offers a cost-effective and versatile networking solution. It provides additional bandwidth at multiple speeds, to meet your network needs without the expense of overhauling your existing cable infrastructure.
The featured NBASE-T technology and multi-gigabit speeds support Cisco campus switches, including Catalyst 4500E, 3850 and 3560-CX. The Marvell 88E2010 chipset is optimized for achieving 2.5 and 5G rates over your existing Cat5e copper cable setup without upgrading to the more expensive Cat6A cabling required for 10Gbps speeds.
The Tehuti Networks TN4010 chipset, compliant with IEEE 802.3az, ensures peak operating efficiency with reduced power consumption. The network card also supports 9K jumbo frames, 802.1q VLAN tagging and is backward compatible with 1000BASE-T. For additional versatility, the controller card is equipped with a standard-profile bracket and includes a low-profile bracket for installation in small form-factor computers.
- StarTech.com 5G PCIe Network Adapter Card, NBASE-T & 5GBASE-T 2.5BASE-T PCI Express Network Interface Adapter, 5GbE/2.5GbE/1GbE Multi Gigabit Ethernet Workstation NIC, 4 Speed LAN Card - 5G PCIe Network Card (ST5GPEXNB) - network adapter - PCIe 2.0 x4 - 5GBase-T x 1
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x4
- PCI Specification Revision
- PCIe 2.0
- Ports
- 5GBase-T x 1
- 2 cm x 12 cm x 8 cm
- 46 g
- Data Link Protocol
- 100Mb LAN, GigE, 5 GigE, 2.5 GigE
- Data Transfer Rate
- 5 Gbps
- Capacity
- Jumbo frame size: 9 KB
- Processor
- Tehuti / Marvell TN4010 / 88E2010P
- IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3bz
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.32 - 4.x LTS versions only, Apple macOS 10.12 - 10.14
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- PCIe 2.0
- Ports
- 5GBase-T x 1
- Connectivity Technology
- Wired
- Fast Ethernet, Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
- 5 Gbps
- Capacity
- Status Indicators
- Link/activity, link/speed
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode, Link Aggregation, VLAN Tagging, promiscuous mode
Processor / Memory
- Processor
- 1 x 1/2.5/5GBase-T - RJ-45
- Included Accessories
- Low-profile bracket
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 2 cm
- 12 cm
- 8 cm
- 46 g
- Shipping Weight
- 55 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 10 - 90%
