StarTech.com 1 Port 5G NBase-T 4 speed PCI Express Network Card
Quicklinx: DZ7FWS00 Mfr#: ST5GPEXNB
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£65.68 ex VAT
£78.81 inc VAT
Add an Ethernet port to a PC client, server or workstation supporting four network speeds: 5G/2.5G/1G/100Mbps. This 4-speed NBASE-T PCIe network card offers an inexpensive network upgrade solution, providing access to your network at multiple speeds up to 5G, using your existing Cat5e copper cabling.
Fully compliant with 2.5GBASE-T, 5GBASE-T, and NBASE-T (Draft IEEE802.3bz) specifications, the PCIe NIC offers a cost-effective and versatile networking solution. It provides additional bandwidth at multiple speeds, to meet your network needs without the expense of overhauling your existing cable infrastructure.
The featured NBASE-T technology and multi-gigabit speeds support Cisco campus switches, including Catalyst 4500E, 3850 and 3560-CX. The Marvell 88E2010 chipset is optimized for achieving 2.5 and 5G rates over your existing Cat5e copper cable setup without upgrading to the more expensive Cat6A cabling required for 10Gbps speeds.
The Tehuti Networks TN4010 chipset, compliant with IEEE 802.3az, ensures peak operating efficiency with reduced power consumption. The network card also supports 9K jumbo frames, 802.1q VLAN tagging and is backward compatible with 1000BASE-T. For additional versatility, the controller card is equipped with a standard-profile bracket and includes a low-profile bracket for installation in small form-factor computers.
StarTech.com 5G PCIe Network Adapter Card, NBASE-T & 5GBASE-T 2.5BASE-T PCI Express Network Interface Adapter, 5GbE/2.5GbE/1GbE Multi Gigabit Ethernet Workstation NIC, 4 Speed LAN Card - 5G PCIe Network Card (ST5GPEXNB) - network adapter - PCIe 2.0 x4 - 5GBase-T x 1
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
5GBase-T x 1
2 cm x 12 cm x 8 cm
46 g
100Mb LAN, 1GbE, 5GbE, 2.5GbE
Data Transfer Rate
5 Gbps
Jumbo frame size: 9 KB
Tehuti / Marvell TN4010 / 88E2010P
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3bz
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.32 - 4.x LTS versions only, Apple macOS 10.12 - 10.14
Network adapter
Plug-in card
PCI Express 2.0 x4
PCIe 2.0
Ports
5GBase-T x 1
Wired
Fast Ethernet, Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
5 Gbps
Status Indicators
Link/activity, link/speed
Auto-negotiation, auto-uplink (auto MDI/MDI-X), full duplex mode, Link Aggregation, VLAN Tagging, promiscuous mode
Processor / Memory
1 x 1/2.5/5GBase-T - RJ-45
Low-profile bracket
Software Included
Drivers & Utilities
2 cm
12 cm
8 cm
46 g
Shipping Weight
55 g
70 °C
10 - 90%
DZ7F StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £206.76
DZ7F StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile In Stock £20.45
DZ7F StarTech.com 4-Port Gigabit NIC - PCIe In Stock £183.65
DZ7F StarTech.com 1-Port Gigabit NIC - PCIe In Stock £30.21
Protocol: Fast Ethernet
Protocol: 2.5 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
