StarTech.com 1-Port 2.5Gbps PoE Network PCIe Card
Quicklinx: HM9YWS00 Mfr#: PR12GIP-NETWORK-CARD
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet, 2.5 Gigabit Ethernet
Form Factor: [N/A]
Compatibility: [N/A]
Type: Network adapter
£83.63 ex VAT
£100.35 inc VAT
This 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity. The variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support for both new and legacy network hardware. Utilize existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
  • Power Over Ethernet
    The PCIe Ethernet card supports the IEEE 802.3af and IEEE 802.3at (Type 1 and Type 2) standards for Power Sourcing Equipment (PSE) and can deliver up to 48V DC and 25.5W of power to compliant Powered Devices (PD). This flexibility eliminates the need for a separate power supply or Power Over Ethernet injector for remote networked devices such as IP cameras, access control devices, remote kiosks, and wireless access points.
  • Increased Network Speed
    The PCIe network card leverages Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and the streaming of online content - while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment.
  • Enhance Existing Hardware
    The network interface card connects via an available x1 PCI Express 2.0 (or higher) expansion slot. The card ships in a standard-profile bracket and includes a low-profile bracket for installation into small form factor systems and servers. This ethernet NIC card is compatible with Windows, Windows Server, VMware, and Linux. This card supports the following advanced features: PXE Boot, WoL, VLAN tagging, 9 K jumbo frame, full-duplex, and Intel vPro technology.
StarTech.com 1-Port 2.5Gbps NBASE-T PoE Network Card, Intel I225-V, 802.3af/at PoE+ Multi-Gigabit NIC, PCI Express Server LAN Card, SATA Powered Desktop Ethernet Interface - Supports Windows, Linux, VMware ESXI (PR12GIP-NETWORK-CARD) - network adapter - PCIe 2.0 - 2.5GBase-T (PoE+) x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
1.6 cm x 11.9 cm x 5.4 cm
62 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 9000
Intel I225-V
IEEE 802.3af, IEEE 802.3at, IEEE 802.3bz, IEEE 802.3ab, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1as, IEEE 802.1x, IEEE P802.3az, IEEE 1588v1
Microsoft Windows 10 / 11, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux 5.8.x or later (LTS versions only), VMware ESXi 7.0
Network adapter
PCI Express 2.0 x1
PCIe 2.0
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity/speed
Intel vPro Technology support, PSE, PXE boot, WOL, VLAN support, full duplex capability, auto-negotiation, Auto MDIX, bus powered, QoS, PTP, EEE
Processor / Memory
Intel I225-V
2 x 2.5 GBase-T (PoE+) - RJ-45
Low-profile bracket
RoHS, WEEE
1.6 cm
11.9 cm
5.4 cm
62 g
Shipping Width
3 cm
Shipping Depth
17 cm
Shipping Height
14 cm
Shipping Weight
70 g
55 °C
5 - 90% RH
HM9Y StarTech.com 1-Port 2.5G PCIe Network Card In Stock £35.59
HM9Y StarTech.com 4-Port RJ45 1G OCP 3.0 NIC In Stock £250.88
HM9Y StarTech.com 2.5Gbps PoE Network Card In Stock £157.40
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: 2.5 Gigabit Ethernet
Form Factor: [N/A]
