StarTech.com 1 Port 2.5Gbps 2.5GBASE-T PCIe Network Card x4 PCIe
Quicklinx: FLYXWS00 Mfr#: ST2GPEX
£26.74 ex VAT
£32.08 inc VAT
This single-port 2.5Gbps PCIe network card offers a versatile and low-cost way to deploy 2.5GbE network connectivity. It adds one copper Ethernet port to your server or desktop computer and provides Multi-Gigabit Ethernet access to your network at four speeds: 2.5 Gbps, 1G, 100Mbps, 10Mbps.
The 2.5GBASE-T NIC provides additional bandwidth using your existing Ethernet infrastructure to help reduce the cost of cabling upgrades. The card enables you to connect to 2.5GBASE-T and NBASE-T equipment at network speeds of 10Mbps, 100Mbps, 1Gbps, 2.5Gbps over your CAT5e cabling (up to 100 m depending on the network configuration).
The network adapter card adds one Ethernet port to your workstation through a x4 PCIe slot. It features 2.5GBASE-T technology, supporting advanced Multi-Gigabit systems, including Cisco campus switches and Aruba Networks access points. The network card also supports NBASE-T and additional features including 16K Jumbo Frames, Auto-MDIX and Wake-on-LAN (WoL).
The Realtek RTL8125 chipset, compliant with IEEE 802.3az and IEEE802.3u supports the PCIe 2.0 interface for PC embedded applications. It provides up to a 250% increase in data rate over Gigabit Ethernet and requires no changes to existing cable infrastructure.
StarTech.com 1 Port PCIe Network Card - 2.5Gbps 2.5GBASE-T PCIe Network Card x4 PCIe - PCI Express LAN Card - RTL8125 (ST2GPEX) - network adapter - PCIe x4 - 10M/100M/1G/2.5 Gigabit Ethernet x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
Ports
12 cm x 8 cm x 2 cm
138 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, NBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Realtek Semiconductor RTL8125
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az, IEEE 802.3bz
Microsoft Windows Server 2008 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2016 R2, Linux 2.4.20 - 4.x LTS versions only
Network adapter
PCI Express x4
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Status
Full duplex mode, Jumbo Frames support, PXE support
Processor / Memory
1 x 2.5Gb Ethernet - RJ-45 - female
Low-profile bracket
FCC, RoHS, REACH
12 cm
8 cm
2 cm
138 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
5 °C
50 °C
20 - 80%
