This single-port 2.5Gbps PCIe network card offers a versatile and low-cost way to deploy 2.5GbE network connectivity. It adds one copper Ethernet port to your server or desktop computer and provides Multi-Gigabit Ethernet access to your network at four speeds: 2.5 Gbps, 1G, 100Mbps, 10Mbps.
The 2.5GBASE-T NIC provides additional bandwidth using your existing Ethernet infrastructure to help reduce the cost of cabling upgrades. The card enables you to connect to 2.5GBASE-T and NBASE-T equipment at network speeds of 10Mbps, 100Mbps, 1Gbps, 2.5Gbps over your CAT5e cabling (up to 100 m depending on the network configuration).
The network adapter card adds one Ethernet port to your workstation through a x4 PCIe slot. It features 2.5GBASE-T technology, supporting advanced Multi-Gigabit systems, including Cisco campus switches and Aruba Networks access points. The network card also supports NBASE-T and additional features including 16K Jumbo Frames, Auto-MDIX and Wake-on-LAN (WoL).
The Realtek RTL8125 chipset, compliant with IEEE 802.3az and IEEE802.3u supports the PCIe 2.0 interface for PC embedded applications. It provides up to a 250% increase in data rate over Gigabit Ethernet and requires no changes to existing cable infrastructure.
Fast data transfer rates
Achieve high-speed networking performance with data transfer rates of up to 2.5 Gbps, enhancing overall productivity and efficiency in data-intensive tasks. -
Versatile protocol support
Compatible with Ethernet, Fast Ethernet, Gigabit Ethernet, and 2.5 Gigabit Ethernet, this card adapts to various networking needs effortlessly. -
Robust operational range
Functionality is maintained in temperatures from 5°C to 50°C, making it suitable for diverse working environments. -
Space-saving design
The low-profile form factor allows for easy integration into compact PCs, maximizing usage of internal space without sacrificing performance. -
Regulatory compliance
Adheres to FCC, RoHS, and REACH standards, ensuring quality and environmental responsibility in its manufacturing.
- Startech 1 Port PCIe Network Card - 2.5Gbps 2.5GBASE-T PCIe Network Card x4 PCIe - PCI Express LAN Card - RTL8125 (ST2GPEX) - network adapter - PCIe x4 - 10M/100M/1G/2.5 Gigabit Ethernet x 1
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x4
- Ports
- 12 cm x 8 cm x 2 cm
- 138 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, NBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Processor
- Realtek Semiconductor RTL8125
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az, IEEE 802.3bz
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2016 R2, Linux 2.4.20 - 4.x LTS versions only
- 2-year warranty
- Network adapter
- Form Factor
- PCI Express x4
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Status Indicators
- Status
- Full duplex mode, Jumbo Frames support, PXE support
Processor / Memory
- Processor
- 1 x 2.5Gb Ethernet - RJ-45 - female
- Included Accessories
- Low-profile bracket
- FCC, RoHS, REACH
- OS Required
- 12 cm
- 8 cm
- 2 cm
- 138 g
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 20 - 80%
