StarTech.com 1 Port 2.5G PoE Network Card
Quicklinx: H13CWS00 Mfr#: ST1000PEXPSE
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet, 2.5 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£83.51 ex VAT
£100.21 inc VAT
The Power over Ethernet PCIe network card enables multigigabit speeds of 2.5/1Gbps and 100/10Mbps. This PoE LAN adapter can provide up to 25.5 W of power to a connected device. It combines a network data connection and power over a single Cat5e (or better) Ethernet cable. This PoE NIC is the ideal solution to provide both power and network communication to a remote installation.
  • Versatile Network PoE Card
    The PCIe Ethernet card supports the IEEE 802.3af and IEEE 802.3at (Type 1 and Type 2) standards for Power Sourcing Equipment (PSE) and can deliver up to 48 V DC and 25.5 W of power to compliant Powered Devices (PD). This flexibility eliminates the need for a separate power source for remote networked devices such as IP cameras, access control devices, remote kiosks, and wireless access points.
  • Enhance Existing Hardware
    The network interface card connects to an available x1 PCIe 2.1 (or higher) expansion slot. The card is shipped with a standard-profile bracket. It includes a low-profile bracket for installation in various computer chassis. Access up to 2.5 Gbps (NBASE-T) speeds using Cat5e cabling to utilize existing networks and equipment. Take advantage of advanced features such as Audio-Video Bridging (AVB) for transmitting real-time content over Ethernet, VLAN tagging, 16K jumbo frame, full-duplex, and PXE. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 1 Port 2.5Gbps PoE Network Card, PCIe Ethernet Card w/RJ45 Port, 30W 802.3at PoE NIC for Desktops/Servers, Network PoE LAN Adapter w/Low-Profile Bracket Included - NBASE-T, Windows/Linux Support (ST1000PEXPSE) - network adapter - PCIe 2.1 - 2.5GBase-T (PoE+) x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.1 x1
Ports
1.5 cm x 9.5 cm x 6.3 cm
220 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, NBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 16000
1 x Realtek Semiconductor RTL8125B
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bz, IEEE P802.3az
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8.1 / 10, Microsoft Windows Server 2019, Microsoft Windows 11, Linux Kernel 2.4.20 or later (LTS versions only)
Network adapter
PCI Express 2.1 x1
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
PoE, link
Flow control, full duplex capability, PoE, WOL, PSE, EEE, VLAN Tagging, RealWoW! Technology, 30W PoE+ power budget, Auto MDIX, PXE boot
Processor / Memory
1 x 1/2.5GBase-T (PoE+) - RJ-45 , 1 x SATA power - 15 pin Serial ATA power , 1 x SP4 power - 4 pin connector - male
Low-profile bracket, full-height bracket
RoHS, WEEE, RCM
Software Included
Drivers & Utilities
1.5 cm
9.5 cm
6.3 cm
220 g
Limited warranty - 2 years , Technical support - assistance - lifetime
50 °C
5 - 95% RH
H13C StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
H13C StarTech.com 12in 15 pin SATA Power Extension Cable In Stock £8.14
H13C StarTech.com 1-Port 2.5Gbps PoE Network PCIe Card In Stock £83.63
H13C StarTech.com 2.5Gbps PoE Network Card In Stock £157.40
Protocol: Fast Ethernet
Protocol: Ethernet
Protocol: 2.5 Gigabit Ethernet
