StarTech.com 1-Port 2.5G M.2 Network Card
Quicklinx: HMP9WS00 Mfr#: MR12GI-NETWORK-CARD
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Form Factor: [N/A]
Compatibility: [N/A]
Type: Network adapter
23 In Stock
£57.60 ex VAT
£69.12 inc VAT
This 2.5 GbE M.2 Network Interface Card (NIC) features an Intel I225-V chipset with Intel vPro technology, for enhanced performance and data integrity. Variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support of new and legacy network hardware. Leverage existing Cat5e or CAT6 cabling infrastructure while adding 2.5GBASE-T (802.3bz) compatibility for seamless integration.
  • Increased Network Speed
    The PCIe network card takes advantage of Intel vPro technology for remote management and troubleshooting capabilities. Improve bandwidth for data-intensive applications, network sharing, FTPs, online or local storage/backup, and online content streaming or uploading while reducing network slowdowns. Access up to 2.5GBASE-T speeds using Cat5e (or better) cabling, to maximize existing networks and equipment.
  • Enhance Existing Hardware
    The network adapter card connects to an available M.2 2280 PCIe slot (B or M key compatible). Standard and low-profile brackets and a 2ft (60cm) Cat6 adapter cable are included for versatile installation. Compatible with Windows, VMware, and Linux.
  • Advanced Features
    This Ethernet card supports the following advanced features: PXE Boot, Wake-on-Lan (WoL), VLAN tagging, 9K jumbo frame, half-duplex, auto-negotiation, and Error Correcting Memory (ECC) for optimal network functionality.
StarTech.com 1-Port 2.5GbE M.2 Network Card, Multi-Gigabit Speeds (2.5G/1G/100M/10M) - NBASE-T (802.3bz), PCIe Ethernet M.2 2280, B/M Key - NIC for SFFs/Desktop PCs, Includes 2ft Cat6 adapter, Full/Low Brackets (MR12GI-NETWORK-CARD) - network adapter - M.2 2280 (B+M Key) - 10/100/1000/2500Base-T x 1 - TAA Compliant
Network adapter
Plug-in card - low profile
Interface (Bus) Type
M.2 2280 (B+M Key)
PCI Specification Revision
PCIe 2.0
Ports
1.5 cm x 2.2 cm x 8 cm
15 g
Cabling Type
Ethernet 2.5GBase-T, Ethernet 1000Base-T, Ethernet 100Base-TX, Ethernet 10Base-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 9000
1 x Intel I225-V
IEEE 802.3bz, IEEE 802.1as, IEEE 802.1p, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE P802.3az, IEEE 1588v1
Red
Linux 5.8.x or later (LTS versions only), Microsoft Windows 10 / 11, VMware ESXi 7.0, Microsoft Windows Server 2019, Microsoft Windows Server 2022
TAA Compliant
Network adapter
M.2 2280 (B+M Key)
PCIe 2.0
Ports
Wired
Cabling Type
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity/speed
Auto-negotiation, Intel vPro Technology support, PXE boot, WOL, VLAN support, VLAN Tagging, half duplex mode, ECC memory, QoS, AVB, EEE, PTP, Auto MDIX, full duplex mode, promiscuous mode, bus powered
Processor / Memory
1 x Intel I225-V
1 x 10/100/1000/2500Base-T - RJ-45
Low-profile bracket, full-height bracket, M3x2 screw
1 x CAT6 adapter cable (external)
Cat5e, CAT 6, WEEE
Red
TAA Compliant
1.5 cm
2.2 cm
8 cm
15 g
Shipping Width
3 cm
Shipping Depth
17 cm
Shipping Height
14.2 cm
Shipping Weight
170 g
HMP9 StarTech.com 1-Port 2.5G PCIe Network Card In Stock £35.26
HMP9 StarTech.com 4-Port RJ45 1G OCP 3.0 NIC In Stock £244.75
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Form Factor: [N/A]
