Add a DB9 serial port to the rear panel of a small form factor/low profile computer. The PLATE9M16LP (16 inch/0.4 m) Low Profile Serial Plate adds a DB9 serial port to the rear panel of a small form factor/low profile computer, connecting to an IDC10 header connector on the motherboard. This durable low profile DB9 bracket is constructed of high quality components.
- StarTech.com 1 Port 16in DB9 Serial Port BRacket to 10 Pin Header - Low Profile - low profile DB9 Header - DB9 bRacket (PLATE9M16LP) - serial panel - DB-9 to 10 PIN IDC - 40.6 cm
- Serial panel
- Low profile
- Length
- 40.6 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 10 PIN IDC - female
- Grey
- Limited lifetime warranty
- Serial panel
- American Wire Gauge (AWG)
- 28
- Low profile
- Length
- 40.6 cm
- Grey
- Connector
- RoHS
