StarTech.com 1-Port 10GbE NIC - PCI Express
Quicklinx: CFQYWS00 Mfr#: ST10000SPEXI
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, 10 Gigabit Ethernet, Fast Ethernet
Form Factor: Plug-in card
Compatibility: PC, Unix
Type: Network adapter
£249.66 ex VAT
£299.59 inc VAT
Upgrade your server or workstation to 10G networking over copper, by adding a 10GBase-T / NBASE-T RJ45 port. Here's a powerful and cost-effective solution for upgrading your server or workstation to 10 Gigabit Ethernet networking over copper. This PCI Express 10G NIC lets you add an Ethernet port to your server or desktop computer and access your network at multiple speeds: 10G, 5G, 2.5G 1G and 100Mbps.
This 10G network card utilizes the Intel X550-AT chipset, delivering the power, performance and enhanced capabilities you need for dependable network connections. Compliant with IEEE 802.3u/ab/an standards, the 1-port 10G card delivers a dependable way to upgrade or replace your existing network port, providing throughput capability of up to 10Gbps in each direction (20Gbps total). It connects easily through a single, four-lane (x4 or higher) PCI Express slot.
The Intel X550-AT chipset provides many advanced features including Intel Virtualization Technology for connectivity and PXE network boot support. The Intel chipset provides many advanced features to support load-balancing the flow of network traffic, to enhance throughput and provide greater data reliability. It supports Audio-Video Bridging (AVB) to enable tightly controlled media stream synchronization, buffering and resource reservation. It also lets you take advantage of advanced features such as VLAN tagging, up to 15K jumbo frame support, Wake-on-LAN and Auto MDIX.
This five-speed NIC provides a cost-effective and versatile networking solution, by giving you the additional bandwidth your network needs without having to overhaul your infrastructure wiring. It lets you add an Ethernet port which can be accessed at multiple speeds 10G, 5G, 2.5G 1G and 100Mbps. Compatible with a broad range of operating systems, the 10G NIC is fully compliant with 10GBase-T and NBASE-T specifications. (10G network speeds require Cat6a cable. All other speeds require Cat5e cable.)
The PCIe 10G network card features advanced NBASE-T technology, supporting the latest multigigabit equipment, including new Cisco campus switches and Aruba Networks access points. The card enables you to connect to NBASE-T based equipment (with Linux only) at network speeds of 2.5Gbps or 5Gbps, over your existing Cat5e infrastructure, without having to upgrade to more expensive Cat6a. The Ethernet network card also supports the more common 10G over copper, and 1G network connections using existing Cat 6/Cat5e or better cabling.
With its dual-profile design, the network card is easy to install into a wide range of computer/server chassis, regardless of form factor. The card comes equipped with a full-sized bracket, and includes a low-profile/half-height installation bracket that you can use as needed.
StarTech.com 1 Port 10G PCIe Network Card - 10GBase-T / NBASE-T - RJ45 Port - Intel X550 Chipset - Ethernet Card - Network Adapter - Intel NIC Card (ST10000SPEXI) - network adapter - PCIe 2.0 - 10Gb Ethernet x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0
Ports
10Gb Ethernet x 1
6.85 cm x 15.25 cm x 12.1 cm
101.8 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T
100Mb LAN, 1GbE, 10GbE
Data Transfer Rate
10 Gbps
Performance
Bandwidth (full duplex): 20 Gbps
Jumbo frame size: 9000
Intel X550-AT
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an
Microsoft Windows Server 2008 R2 x64 Edition, VMware ESXi 5.1, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, VMware ESXi 5.5, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), VMware ESXi 6.0, Microsoft Windows Server 2016 (64-bit), Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 (64-bit)
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
Network adapter
PCI Express 2.0
Ports
10Gb Ethernet x 1
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Performance
Flow control, full duplex mode, Jumbo Frames support, PXE support, tagged VLAN
Processor / Memory
Intel X550-AT
1 x 10GBase-T - RJ-45
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
6.85 cm
15.25 cm
12.1 cm
101.8 g
5 °C
50 °C
20 - 80%
CFQY StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £18.74
CFQY StarTech.com 1-Port Gigabit NIC - PCIe In Stock £28.06
Protocol: 10 Gigabit Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Compatibility: Unix
