StarTech.com 1 Port 10G NIC w/ Chassis
Quicklinx: DXG2WS00 Mfr#: BNDTB10GI
This Thunderbolt 3 to 10GbE adapter lets you connect your Thunderbolt 3 enabled device to a 10 GbE network via an expansion chassis. This Thunderbolt 3 to 10GbE NIC lets you connect your Thunderbolt 3 enabled device to a 10 GbE network. This adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the PCI Express 10G NIC (ST10000SPEXI), giving you one DisplayPort output, one additional Thunderbolt 3 port and one RJ45 (10GbE) port.
This 10G network card utilizes the Intel X550 chipset with Intel Virtualization Technology for connectivity, delivering the power, performance and enhanced capabilities you need for dependable network connections.
Requiring only a Phillips type screwdriver, this Thunderbolt 3 to 10GbE NIC can be assembled and connected in minutes. It connects easily through a single Thunderbolt 3 port on your computer.
The Thunderbolt 3 chassis not only pairs well with the 10GbE NIC - you can swap the NIC out for other PCIe cards, to help support other functionality and performance. With the extra TB3 port and DP output built into the chassis, you will always have the ability to hook up extended displays to effortlessly multitask.
StarTech.com Thunderbolt 3 to 10GbE NIC Chassis + Card - network adapter - PCIe 3.0 x4 - 1/2.5/5/10GBase-T x 1
Network adapter
Plug-in card - low profile
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCI 3.0
Ports
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
10 Gbps
Jumbo frame size: 9000
Intel X550-AT
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3q
Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits), Apple macOS 10.12 - 10.13
Network adapter
Bundled with
PCI Express 3.0 x4
PCI 3.0
Ports
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Flow control, full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support, 1 fan, VLAN Tagging
Processor / Memory
Intel X550-AT
1 x 1/2.5/5/10GBase-T - RJ-45 - female
Low-profile bracket
1 x Thunderbolt 3 / USB-C cable (external) - 50 cm
FCC, RoHS, WEEE
5 °C
35 °C
20 - 80%
DXG2 StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £49.12
DXG2 StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length In Stock £327.11
DXG2 StarTech.com PCI Express X1 to X16 Low Profile Slot Extension Adapter In Stock £19.72
DXG2 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
DXG2 StarTech.com 4 Port PCI Express PCIe Serial Combo Card - 2 x RS232 2 x RS422 / RS485 In Stock £110.54
DXG2 StarTech.com 1 Port PCI Express PCIe Gigabit Network Server Adapter NIC Card - Dual Profile In Stock £18.74
DXG2 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £46.45
DXG2 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £80.54
DXG2 StarTech.com USB-C to VGA Adapter In Stock £22.16
DXG2 StarTech.com 4-Port Gigabit NIC - PCIe In Stock £151.83
DXG2 StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
DXG2 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £21.26
DXG2 StarTech.com USB-C to HDMI Adapter In Stock £15.52
DXG2 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
DXG2 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
DXG2 StarTech.com U.2 to PCIe Adapter -SFF-8639 In Stock £24.76
