StarTech.com 1 m/3.3 ft USB C to Lightning Cable - Black
Quicklinx: FLYQWS00 Mfr#: RUSBCLTMM1MB
Length: 1m
£9.43 ex VAT
£11.31 inc VAT
This 1 m (3 ft.) black USB C to Lightning cable withstands the daily demands of charging and syncing your iPad, iPhone or other mobile devices featuring the Lightning connector. Tested to endure strenuous wear and tear and winter and summer in-car use, the strong and rugged cable is a must-have for both business and consumer applications.
The durable USB C to Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the heavy duty cable flex without over-stretching and strengthens the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The reinforced cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features. Lightning connector provides 12W so your charger can charge your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
  • Built for daily use
    The durable USB-C to Lightning cable has aramid fiber reinforcement that shelters it from the stress of frequent bends and twists. This also lets the heavy duty cable flex without over-stretching and strengthens the core of the cable.
  • Apple MFi-certified
    USB-C to Lightning adapter cable for guaranteed fast and reliable charge/sync from USB-C charger port for Lightning devices.
StarTech.com 3 ft(1m) Durable Black USB-C to Lightning Cable, Heavy Duty Rugged Aramid Fiber USB Type C to Lightning Charger/Sync Power Cord, Apple MFi Certified iPad/iPhone 12 Pro Max - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB 2.0 - 1 m
Cable
American Wire Gauge (AWG)
22/32
Length
1 m
Connector
Lightning - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
Sync and charge, strain relief, EMI/RFI protection
Cable Type
Lightning cable
Interface Supported
Lightning / USB 2.0
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
USB / USB 2.0
Length
1 m
Plated Connector
Nickel
Recommended Use
Mobile phone, portable player, tablet
Connector
Apple Lightning - male
24 pin USB-C - male
RoHS, REACH, MFI, EMI
1.2 cm
0.6 cm
25 g
Shipping Width
7.5 cm
Shipping Depth
14.5 cm
Shipping Height
1.7 cm
Shipping Weight
30 g
FLYQ StarTech.com 1 m/3.3 ft USB C to Lightning Cable - White In Stock £16.47
FLYQ StarTech.com 2 m/6.6 ft USB C to Lightning Cable - White In Stock £18.47
Length: 1m
