Mirror the output from a VGA source to two VGA monitors. This VGASPL1VV 1-foot VGA video splitter cable lets you connect two VGA displays to a single VGA video source.
                Reliable ConnectionThis VGA splitter cable ensures a stable connection between devices, allowing for uninterrupted video transmission to multiple monitors.
                High-Quality ConstructionThe use of 28 AWG wire and gold-plated connectors enhances durability and optimizes signal clarity for a viewing experience.
                Dual Monitor SupportThis cable facilitates the connection of two monitors to a single VGA output, ideal for presentations or multitasking environments.
                Quick SetupEasily connect and configure VGA devices without complicated installation processes, suitable for both home and office use.
- StarTech.com 1 ft. VGA to VGA Splitter Cable - M/F Dual Monitor Video Cable Splitter (VGASPL1VV) - VGA splitter - 30 cm
- VGA splitter
- Length
- 30 cm
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- 2 x HD-15 (VGA) - female
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
- VGA splitter
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Gold
- Length
- 30 cm
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 2 x 15 pin HD D-Sub (HD-15) - female
- RoHS
- Designed For
|  | StarTech.com 2 Port VGA Video Splitter - USB Powered | In Stock | £18.20 |
