Mirror the output from a VGA source to two VGA monitors. This VGASPL1VV 1-foot VGA video splitter cable lets you connect two VGA displays to a single VGA video source.
Reliable Connection
This VGA splitter cable ensures a stable connection between devices, allowing for uninterrupted video transmission to multiple monitors. -
High-Quality Construction
The use of 28 AWG wire and gold-plated connectors enhances durability and optimizes signal clarity for a viewing experience. -
Dual Monitor Support
This cable facilitates the connection of two monitors to a single VGA output, ideal for presentations or multitasking environments. -
Quick Setup
Easily connect and configure VGA devices without complicated installation processes, suitable for both home and office use.
 - StarTech.com 1 ft. VGA to VGA Splitter Cable - M/F Dual Monitor Video Cable Splitter (VGASPL1VV) - VGA splitter - 30 cm
 - VGA splitter
- Length
 - 30 cm
- Connector
 - HD-15 (VGA) - male
- Connector (Second End)
 - 2 x HD-15 (VGA) - female
 - RoHS
 - Black
 - Limited lifetime warranty
- Designed For
 - P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
 - VGA splitter
- American Wire Gauge (AWG)
 - 28
- Plated Connector
 - Gold
- Length
 - 30 cm
 - Black
- Connector
 - 15 pin HD D-Sub (HD-15) - male
 - 2 x 15 pin HD D-Sub (HD-15) - female
 - RoHS
- Designed For
                        StarTech.com 2 Port VGA Video Splitter - USB Powered | In Stock | £18.20 |
