Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F
Quicklinx: 76VTWS00 Mfr#: VGASPL1VV
Type: VGA
Length: 30cm
Hurry, only 2 left in stock!
£13.14 ex VAT
£15.76 inc VAT
Mirror the output from a VGA source to two VGA monitors. This VGASPL1VV 1-foot VGA video splitter cable lets you connect two VGA displays to a single VGA video source.
  • Reliable Connection
    This VGA splitter cable ensures a stable connection between devices, allowing for uninterrupted video transmission to multiple monitors.
  • High-Quality Construction
    The use of 28 AWG wire and gold-plated connectors enhances durability and optimizes signal clarity for a viewing experience.
  • Dual Monitor Support
    This cable facilitates the connection of two monitors to a single VGA output, ideal for presentations or multitasking environments.
  • Quick Setup
    Easily connect and configure VGA devices without complicated installation processes, suitable for both home and office use.
StarTech 1 ft. VGA to VGA Splitter Cable - M/F Dual Monitor Video Cable Splitter (VGASPL1VV) - VGA splitter - 30 cm
VGA splitter
Cable Length
30 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
2 x HD-15 (VGA) - female
RoHS
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
VGA splitter
American Wire Gauge (AWG)
28
Plated Connector
Gold
Cable Length
30 cm
Connector
2 x 15 pin HD D-Sub (HD-15) - female
RoHS
76VT StarTech.com 2 Port VGA Video Splitter - USB Powered In Stock £13.81
Type: VGA
Length: 30cm
