Connect a USB 3.0 Micro USB External Hard drive to your computer. The USB3SAUB1 1-foot SuperSpeed USB 3.0 Cable (A to Micro B) offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
The cable features high quality Shielded Twisted Pair (STP) construction, helping to prevent electro-magnetic interference and ensuring reliable data communication, which ensures a quick and easy way to connect to an external storage solution for throughput of up to 5 Gbps when used with a USB 3.0 host and device.
The 1 ft USB 3.0 A to Micro B cable provides guaranteed quality and reliability.
- StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B - 30cm USB 3 to Micro B Cord (USB3SAUB1) - USB cable - USB Type A to Micro-USB Type B - 31 cm
- USB cable
- Technology
- Shielded twisted pair (STP)
- Molded, 5 Gbps data rate
- Length
- 31 cm
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- USB 3.0
- Blue
- Limited lifetime warranty
- Designed For
- P/N: BNDTBUSB3142, DKT30CVAGPD, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251BU31315, S252BU313R, SLSODDU33B, SM21BMU31C3, SM22BU31C3R, SMS1BMU313, SMS2BU31C3R
- USB cable
- Technology
- American Wire Gauge (AWG)
- 28
- Length
- 31 cm
- Blue
- Connector
- USB 3.0, RoHS
- Designed For
- P/N: BNDTBUSB3142, DKT30CVAGPD, ECUSB3S11, ECUSB3S22, ECUSB3S254F, PCIUSB3S22, PCIUSB3S4, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311EI, PEXUSB312A1C1H, PEXUSB312A2, PEXUSB312A2C2V, PEXUSB312EIC, PEXUSB314A2V, PEXUSB314A2V2, S2510BMU33, S2510BPU33, S2510BPU337, S2510BU33PW, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251BU31315, S251SMU33EP, S252BU313R, SAT2510BU32, SLSODDU33B, SM21BMU31C3, SM22BU31C3R, SM2NGFFMBU33, SMS1BMU313, SMS2BU31C3R, UNI251BMU33
