Easily connect an iPod or other MP3 player to a car stereo.
This 1-foot Slim 3.5mm Right Angle to Right Angle Stereo Audio Cable is the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), featuring a slim connector molding that fits easily into a 3.5mm headphone jack, even if the device is in a protective case.
For those difficult to reach areas, the Right Angle 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal (straight) stereo audio connector cannot.
Convenient connector design
The right-angled connectors allow for easy connections in tight spaces, reducing strain on your devices. -
Reliable audio quality
Gold plating on the connectors ensures a stable and clear audio signal for an enhanced listening experience. -
Durable construction
Crafted with a sturdy PVC jacket, this cable is designed to withstand daily use while maintaining excellent performance. -
Flexible and portable
The lightweight 30 AWG design makes it easy to carry and use, whether at home or on the go. -
Environmentally friendly
Meeting RoHS compliance standards, this product is produced with materials that are safe for the environment.
- StarTech.com 1 ft. (0.3 m) Right Angle 3.5 mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU1MMS2RA) - audio cable - 30 cm
- Cable
- Audio cable
- American Wire Gauge (AWG)
- 30
- Length
- 30 cm
- Black
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- Right-angled connector
- Limited lifetime warranty
- Cable Type
- Audio cable right-angled connector
- 30
- Jacket Material
- PVC
- Length
- 30 cm
- Plated Connector
- Gold
- Black
- Connector
- RoHS
- Limited warranty - lifetime
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.50 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M | In Stock | £2.88 |
StarTech.com 3.5 Right Angle Stereo Cable | In Stock | £4.48 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M | In Stock | £4.40 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.14 |
