StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M
Quicklinx: 7B5WBTBS Mfr#: MU1MMS2RA
Type: Audio
Length: 30cm
More than 50 In Stock
£2.87 ex VAT
£3.44 inc VAT
Easily connect an iPod or other MP3 player to a car stereo.
This 1-foot Slim 3.5mm Right Angle to Right Angle Stereo Audio Cable is the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), featuring a slim connector molding that fits easily into a 3.5mm headphone jack, even if the device is in a protective case.
For those difficult to reach areas, the Right Angle 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal (straight) stereo audio connector cannot.
  • Convenient connector design
    The right-angled connectors allow for easy connections in tight spaces, reducing strain on your devices.
  • Reliable audio quality
    Gold plating on the connectors ensures a stable and clear audio signal for an enhanced listening experience.
  • Durable construction
    Crafted with a sturdy PVC jacket, this cable is designed to withstand daily use while maintaining excellent performance.
  • Flexible and portable
    The lightweight 30 AWG design makes it easy to carry and use, whether at home or on the go.
  • Environmentally friendly
    Meeting RoHS compliance standards, this product is produced with materials that are safe for the environment.
StarTech.com 1 ft. (0.3 m) Right Angle 3.5 mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU1MMS2RA) - audio cable - 30 cm
Cable
Audio cable
American Wire Gauge (AWG)
30
Length
30 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Right-angled connector
Cable Type
Audio cable right-angled connector
30
Jacket Material
PVC
Length
30 cm
Plated Connector
Gold
Connector
RoHS
Limited warranty - lifetime
7B5W StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
7B5W StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
7B5W StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £2.87
7B5W StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.51
7B5W StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
7B5W StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £4.47
7B5W StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M In Stock £4.49
7B5W StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
7B5W StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £6.20
Type: Audio
Length: 30cm
