StarTech.com 1 ft Panel Mount USB Cable B to B - F/M
Quicklinx: 6BC1WS00 Mfr#: USBPNLBFBM1
Length: 30cm
22 In Stock
£5.68 ex VAT
£6.81 inc VAT
For customized USB device solutions; allows the USB connection to be mounted on a secure easily accessible panel. The USBPNLBFBM1 USB B to USB Panel mount cable features a USB type B male connector on one end, and a USB panel mount B (female) molded connector on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M - USB cable - USB Type B (F) to USB Type B (M) - USB 2.0 - 1 ft - molded, thumbscrews - black - USBPNLBFBM1 - USB cable - USB Type B to USB Type B - 30 cm
USB cable
Molded, thumbscrews
Length
30 cm
Connector
4 pin USB Type B - female
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
USB cable
Molded, thumbscrews
Length
30 cm
Connector
USB / USB 2.0, RoHS
6BC1 StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.85
6BC1 StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.20
6BC1 StarTech.com 3 ft Panel Mount USB Cable B to B - F/M In Stock £6.14
Length: 30cm
