Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM1 1ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 1ft, enabling you to place the cable as needed within the system case.
- StarTech.com 1 ft Panel Mount USB Cable A to A - F/M - USB extension cable - USB (M) to USB (F) - USB 2.0 - 1 ft - molded, thumbscrews - black - USBPNLAFAM1 - USB extension cable - USB to USB - 30 cm
- Molded, thumbscrews
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: UUSBOTG
- Length
- 30 cm
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- P/N: UUSBOTG
|  | StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.92 |
|  | StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.69 |
|  | StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.34 |
|  | StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £15.06 |
|  | StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.02 |
|  | StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.04 |
|  | StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.29 |
|  | StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter | In Stock | £18.52 |
|  | StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.44 |
|  | StarTech.com 3 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.33 |
|  | StarTech.com 2 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.11 |
