Add an external panel mount USB connection to a PC or faceplate. The USBPNLAFAM1 1ft Panel Mount USB Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB devices is required.
The adapter features one male USB-A connector and one female panel mount USB-A port and gives you an extension of 1ft, enabling you to place the cable as needed within the system case.
- StarTech.com 1 ft Panel Mount USB Cable A to A - F/M - USB extension cable - USB (M) to USB (F) - USB 2.0 - 1 ft - molded, thumbscrews - black - USBPNLAFAM1 - USB extension cable - USB to USB - 30 cm
- Molded, thumbscrews
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: UUSBOTG
- Length
- 30 cm
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
- P/N: UUSBOTG
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.23 |
StarTech.com 3 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.66 |
StarTech.com 2 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.40 |
