This 1ft USB to Panel mount USB cable features a 5-pin motherboard header connection on one end and a panel mount USB A (female) port on the other, providing a simple and easy to access USB 2.0 port on a panel mount receptacle.
The USB panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB connection.
- StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable Adapter F/F - USB 2.0 internal Cable (USBPNLAFHD1) - USB internal to external cable - USB to 5 pin USB 2.0 header - 30 cm
- Thumbscrews
- Length
- 30 cm
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 5 pin USB 2.0 header - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Thumbscrews
- Length
- 30 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.14 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.49 |
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £17.51 |
StarTech.com 3 ft Panel Mount USB Cable USB A to Motherboard Header Cable F/F | In Stock | £6.15 |
StarTech.com USB IDC Motherboard Cable | In Stock | £3.86 |
