StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B
Quicklinx: 76VPWS00 Mfr#: UUSBHAUB1LA
Length: 30cm
24 in stock
£1.87 ex VAT
£2.24 inc VAT
Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB1LA 1-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smartphones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB1RA 1ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B - USB cable - 30 cm
USB cable
90° connector, left-angled connector
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
American Wire Gauge (AWG)
30
Length
30 cm
Connector
USB / USB 2.0, RoHS
76VP StarTech.com Micro USB to Mini USB Adapter In Stock £4.96
76VP StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.92
76VP StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.73
76VP StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B In Stock £1.87
76VP StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.76
76VP StarTech.com 6in Micro USB Cable - A to Micro B In Stock £3.46
76VP StarTech.com 6 ft Micro USB Cable A to Left Angle Micro B In Stock £4.78
76VP StarTech.com 3 ft Micro USB Cable - A to Left Angle Micro B In Stock £3.87
Length: 30cm
Price Range Ex VAT: 0 - 50
