Charge or sync your Micro-B USB devices with the cable out of the way. The UUSBHAUB1LA 1-foot USB-A to Micro-B Cable provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smartphones, digital cameras, PDAs, Tablet PC devices and GPS systems, etc.) and a USB-capable computer, for everyday tasks such as data synchronization, file transfers and charging.
The left-angled Micro USB connector positions the cable in such a way that it allows you to easily access your mobile digital device in both portrait and landscape mode, even while charging.
As an alternative, StarTech.com also offers a UUSBHAUB1RA 1ft USB A to Right Angle Micro B Cable, which provides the same convenience as this left-angled cable but allows you to connect to your USB Micro-B devices from the opposite direction.
- StarTech.com 1 ft. (0.3 m) USB to Micro USB Cable - USB 2.0 A to Left Angle Micro B - Black - Micro USB Cable (UUSBHAUB1LA) - USB cable - USB to Micro-USB Type B - 30 cm
- USB cable
- Left-angled connector, 90° connector
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
- USB cable
- American Wire Gauge (AWG)
- 30
- Length
- 30 cm
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £4.99 |
