StarTech.com 1 ft DVI-I Analog to 2x VGA Video Splitter Cable - M/F
Quicklinx: 76M3WS00 Mfr#: DVISPL1VV
Display a DVI-I signal on two VGA monitors simultaneously. The DVISPL1VV 1ft DVI to Dual VGA Cable lets you to connect two VGA displays, or projectors to a single DVI-I analog video output port on your computer.
The DVISPL1VV is a reliable and cost-effective solution for splitting a single DVI-I video signal between two monitors in order to get the most out of your video card.
StarTech.com 1 ft / 30cm DVI to Dual VGA Y Splitter Cable - DVI-I Analog to Dual VGA, 1x DVI-I (M), 2x VGA (F) (DVISPL1VV) - display splitter - 30 cm
Display splitter
Length
30 cm
Connector
2 x HD-15 (VGA) - female
Connector (Second End)
DVI-I - male
RoHS
Display splitter
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
30 cm
Connector
2 x 15 pin HD D-Sub (HD-15) - female
18+5 pin combined DVI (Single-Link) - male
RoHS
