StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 76P3WS00 Mfr#: MXT101MMHQ1
Type: VGA
Length: 31cm
£5.99 ex VAT
£7.18 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXT101MMHQ1 High Resolution VGA Cable (1 ft) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com VGA to VGA Cable - 1 ft - HD15 M/M - Coax High Resolution - Computer Monitor Cable - Video Cable - VGA Monitor Cable (MXT101MMHQ1) - VGA cable - 31 cm
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
31 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
P/N: BNDDKTCHVPRS, CDP2VGA, CDP2VGAFC, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVW, DP2VGA3X5, DP2VGAA, HD2DPVGADVI, HDVGADP2HD, MDP2HDVGAW, MSTS3MDPUGBK, SV231USBLC, USB32HDVGA
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
31 cm
Connector
RoHS
P/N: BNDDKTCHVPRS, CDP2VGA, CDP2VGAFC, CDP2VGAUACP, CDP2VGAUCP, CDP2VGAUCPW, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHV, DKT30CHVCM, DKT30CHVGPD, DKT30CHVW, DP2VGA, DP2VGA2, DP2VGA3, DP2VGA3X5, DP2VGAA, DP2VGDVHD, DVI2VGAE, DVI92030202L, DVISPL1VV, DVIVGAMF, DVIVGAMFBK, HD2DPVGADVI, HD2VGAA2, HD2VGAE2, HD2VGAMICRO, HDVGADP2HD, MCHD2VGAE2, MDP2HDVGA, MDP2HDVGAW, MDP2VGA, MDP2VGA2, MDP2VGAW, MNHD2VGAE2, MSTP3MDPUGBK, MSTS3MDPUGBK, RACKCONS1908, SV1631DUSBUK, SV231DDVDUA, SV231USB, SV231USBLC, SV431DDVDUA, SV431USB, USB2VGAE2, USB2VGAE3, USB2VGAPRO2, USB32HDVGA, USB32VGAES, USB32VGAPRO, VGA2VID, VGAPLATE
76P3 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.82
76P3 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.12
76P3 StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
76P3 StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.99
Type: VGA
Length: 31cm
Price Range Ex VAT: 0 - 50
